Deploying the Newly Merged Repository Definition (.rpd) File
You can now deploy the newly merged Repository Definition (.rpd) file in Oracle Business Intelligence (OBI). To deploy the newly merged Repository Definition (.rpd) file, complete the following steps:
- Open a terminal or command prompt window and go to your BI Domain tools folder. For example:
C:\Oracle\Middleware\Oracle_Home\user_projects\domains\bi\bitools\bin
- Use the data-model-cmd.cmd command (with Windows) or the data-model-cmd.sh command (with UNIX or Linux) in the terminal or command prompt to upload the newly merged Repository Definition file using your WebLogic administrator credentials (the -U and –P parameters). For example:
data-model-cmd.cmd uploadrpd –I C:\Temp\OraclePrimaveraAnalytics162.rpd –W Admin123 –U weblogic –P weblogic1 –SI ssi
You should receive a message indicating that the RPD Upload completed successfully.
- Log in to the OBI Enterprise Manager URL with an account that is a member of the WebLogic Administrator group (for example, weblogic):
http://<server>:<port>/em
where <server> is the server name or IP address of the server where OBI is installed and running, <port> is the listening port number for OBI, and /em is the default context for OBI Enterprise Manager.
- Click the Target Navigation Tree icon at the upper left corner of the scree to expand it.
- Click the arrow icon next to the Business Intelligence leaf node to expand the folder.
- Click the biinstance hyperlink, which appears below the leaf node, to display the properties and available configuration options for this deployment of OBI on the right side of the screen.
- Click the Availability parent tab
- Click the Processes child tab.
- Click the Restart All link to restart all components of this OBI deployment.
- When the confirmation window appears, click Yes.
When the OBI deployment restarts, a confirmation message appears.
- Click Close.
- Click the user menu (for example, weblogic) located at the upper right of the screen directly below the browser toolbar, and select Log Out.
Last Published Wednesday, July 3, 2024
