Verifying the MapViewer Connection
Complete the following steps to verify the MapViewer connection:
- Access the MapViewer by going to the following URL:
http://<machine>.<domain>:9704/mapviewer
- Log in to MapViewer using the same administration user that you use to log in to the WebLogic and Enterprise Manager consoles.
- Select the Admin link.
- Select Data Sources.
You should see the data source that you just created. You should also see your machine.domain in your configuration if the changes were successfully committed.
Last Published Wednesday, July 3, 2024
