Configuring Background Maps for MVDEMO
After importing the necessary map layers, complete the following steps to associate the background maps with map layers created in the previous section.
- Log into OBI with an account that has BI Administrator role.
- Click Administration.
- Under Map Data Management, click Manage Map Data.
- In the Manage Map Data page:
- Select the Background Maps tab.
- Select Import Background Maps.
- In the Import Background Maps dialog box:
- In the Look in field, choose mvdemo.
- In the Available Maps field, choose ELOCATION_MAP.
- Select OK.
- Select the ELOCATION_MAP you added and select Edit Background Map.
- In the Edit Background Map dialog box:
- In the Name field, enter City Map.
- In the Interactive BI Layers section, click +.
- In the Add Layers pop-up, select ALL CITIES.
- Click OK.
- Adjust the zoom level as needed.
- Click OK.
- Repeat the above steps to add a country, state, and combination country/state/city maps.
Notes:
- When you create a country map, name it Country Map and add the ALL COUNTRIES BI layer.
- When you create a state map, name it State Map and add the US STATES BI layer.
When you create a country/state/city map, name it Country State City Map and add the ALL COUNTRIES, US STATES, and ALL CITIES BI layers.
Last Published Wednesday, July 3, 2024
