System Requirements
For the operating system and hardware requirements, refer to the Hardware Software requirements guide.
Before creating a new SoftRater environment, ensure to have the following setup:
  • Run the docker script to create an IBSS instance on JBoss EAP 7.4
  • Database name or Environment name
  • Database login information
  • Database server name, either IP or DNS
  • Database DDL, updates or backup files for the database you want to utilize. SQL Server backups files are located in the Insbridge-Windows folder. DDLs and updates are located in the SoftRater file on the Install Server
  • If utilizing Oracle, you need: DB Catalog name, port number, and DB Schema name
  • Subscriber ID created in IBFA
  • Access to the server where the Insbridge system was installed
  • URL of the current IBFA
  • Package location where you want the packages stored
These components will be needed at various times during the installation and implementation of SoftRater for C.
The Insbridge-Windows folder contents:
  • Databases
    • Oracle
    • SoftRater
    • Batch
    • IBSS561IA20.1.zip
  • Oracle Insurance Insbridge Enterprise Rating (x64).exe
The 5.6.3-Insbridge-JBoss EAP folder contents are:
  • IBSS.EAR
  • Docker script file
  • Insbridge.net.softraterconfig.xml No license file is required. (Should be available as part of 5.6.3 install)
The SoftRater can be installed any time after the Insbridge Framework Administrator and RateManager have been installed. The SoftRater must be installed prior to any users creating packages.
Note: All folders and files may not be needed, depending upon the kind of setup you want.
