Step 4: Assigning Permissions: Windows Temp Folder
Permissions must be assigned for the Windows Temp Folder for MSMQ and for the application pool default identity. Prior to assigning permissions, please verify the Insbridge application pool identity.
Assigning Permissions in the Windows Temp Directory:
  1. Find the WINDOWS folder, most likely on your C drive.
  2. Right-click the Windows -> Temp folder.
  3. Temp folder
  4. Click Properties. The Temp Properties screen opens.
  5. Click the Security tab.
  6. Click Edit.
  7. On the Permissions for Temp screen, click the Insbridge user and then, click Add. If the Insbridge user is not found, cancel out and return to the Local Users and Groups area in Server Manager and verify that the Insbridge user was created.
  8. Update the permissions. The Insbridge user requires Full control.
  9. Permission for Temp
  10. Click OK to close the Permissions for Temp screen.
  11. Click OK to close the Temp Properties screen.
