A.7 Locate Product Documentation on the Oracle Help Center
Oracle Communications customer documentation is available on the web at the Oracle
Help Center (OHC) site, http://docs.oracle.com. You do not have to register to access
these documents. Viewing these files requires Adobe Acrobat Reader, which can be
downloaded at Adobe.
- Access the Oracle Help Center site at Oracle.
- Click Industries.
- Under the Oracle Communications subheading, click Oracle Communications documentation link. The Communications Documentation page appears. Most products covered by these documentation sets display under the headings Network Session Delivery and Control Infrastructure or Platforms.
- Click on your Product and then the Release Number. A list of the entire documentation set for the selected product and release displays.
- To download a file to your location, right-click the PDF link, select Save target as (or similar command based on your browser), and save to a local folder.
