About Columns (Fields)
Fields hold data. They generally either allow you to enter values or just display the current value for the field (called a read-only field). Pages with tables often permit you to configure the fields that make up the columns of the table. Some pages with grid views also allow you to pin columns to the start of the column list so they are always visible, even when you scroll.
The list of columns available for you to add to a view may depend on the circumstances. For example, some baseline fields (such as actual baseline cost fields, and many baseline date fields) can only be added to the view if you have assigned a baseline to the project (rather than using the current project as the baseline).
Tips:
- In the EPS, Activities, and Assignments pages, select Show Hint Help (Alt+F1) to view a description of a column when you hover over the column heading.
Related Topics
Showing or Hiding Columns in a Table
Last Published Wednesday, November 27, 2024
