Assigning a Team Member Work Distribution Filter
Assign Team Member work distribution filters to enable Team Member interface users to update progress for selected labor resources, roles, and global and EPS activity codes.
To assign a Team Member work distribution filter:
  1. Click Administration.
  2. On the Administration navigation bar, click User Administration.
  3. In the User Administration pane, click Users.
  4. On the Users page:
    1. Select a user.
    2. In the Team Member Filter field, double-click and click Select.
      Note: If the Team Member Filter option is not displayed, click Customize View and select Team Member Filter.
  5. In the Team Member Filter dialog box:
    1. Select the Selected option for each filter you want to assign to the selected user.
    2. Click Save.
  6. On the Users page, click Save.
Tips
Related Topics
About Team Member Work Distribution Filters
Creating a Team Member Work Distribution Filter
Last Published Wednesday, November 27, 2024
