Linking P6 and Primavera Unifier Applications Using Schedule Sheets
Perform the steps below to link P6 to Primavera Unifier using schedule sheet integration. This link at the application level allows you to establish links at the project level. When the applications and projects are linked, P6 users can send data to Primavera Unifier schedule sheets.
To link P6 to Primavera Unifier using schedule sheet integration:
  1. Click Administration.
  2. On the Administration navigation bar, click Application Settings.
  3. On the Application Settings page, click the Integration and Allow Lists tab.
  4. On the Integration and Allow Lists tab:
    1. Enter a URL in the Primavera Unifier URL field of the Unifier section.
    2. Enter a Primavera Unifier integration user name in the Integration User Name field.
    3. Enter the Primavera Unifier password for the integration user name in the Password field.
    4. Click Save and Close.
Tip:
You need the Edit Application Settings privilege to edit the settings in the Application Settings page.
Related Topics
Configuring Integration & Allow Lists Settings
Configuring Clickable Websites
Configuring Allowed Client IP Address Ranges
Last Published Wednesday, November 27, 2024
