Opening Projects or Templates
Perform these steps to open one or more projects or a single template in order to view or modify project data on any of the pages in the Projects section of the application. You can open templates and projects from several locations in the application; however, these steps using the common selection controls on the Open Projects dialog box represent the standard way to determine and change which projects are currently open.
To open a project or template:
  1. Click the Projects menu and select Open Projects.
  2. In the Open Projects dialog box:
    1. Click Projects or Templates.
    2. Select an item from the Organize By list to choose a viewing arrangement.
    3. Use the common selection controls to identify and select the items you want to open.
      • In the Available Templates list, add a template to the Selected Templates list.
      • In the Available Projects list, add one or more projects, or an entire group of projects, to the Selected Projects list.
    4. Click OK.
Tips
Related Topics
About Projects
Creating Projects
Creating Projects from Existing Projects or Templates
Creating Project Templates from Existing Projects or Templates
Deleting Projects or EPS Elements
Customizing Detail Windows
Configuring Project Preferences
About Opening a Project Exclusively
Opening Projects Exclusively
Removing the Exclusive Lock on Projects
Last Published Wednesday, November 27, 2024
