Adding Configurations to the Primavera P6 Administrator
Duplicate an existing configuration to create a new configuration. To duplicate a configuration:
- Select Manage Configurations in the Configurations list.
- Select the menu button next to a configuration and select Duplicate.
- Double-click the new configuration.
- Enter a name for the configuration.
- Select Save.
- Edit settings as needed.
- Click Save Changes.
Tips:
- To create a new configuration based on default settings, duplicate the Factory Defaults configuration.
- If you create a new configuration, you must click Update to latest version before changing your settings in the new configuration.
Related Topics
Reviewing and Modifying Configurations for P6
Changing a Setting in the Primavera P6 Administrator
Returning a Primavera P6 Administrator Setting to its Default Value
Adding Database Instances to a Configuration in the Primavera P6 Administrator for On-Premises
Exporting Configurations Using the Command Line for On-Premises
Last Published Monday, July 14, 2025
