Configuring P6 Integration API Authentication
Because one P6 Integration API server instance can control more than one database, in addition to specifying an authentication mode for a database through the Authentication tab of the Primavera P6 Administrator, you can use an administrative configuration setting to specify the overall mode you want to use for the P6 Integration API server. The P6 Integration API uses a single P6 Professional configuration setting, Authentication.Mode, to support authentication selection. For LDAP authentication with secure communication (SSL) between the P6 Integration API server and the LDAP server, two additional configuration settings are required.
Use the Primavera P6 Administrator to specify these configuration settings.
Note: A P6 Integration API configuration might include database instances that are not set to the same authentication mode as the P6 Integration API server. If a user connects and requests a database that is set to a different authentication mode than the P6 Integration API server, an error message displays. The user must select a database that matches the authentication mode set for the P6 Integration API server.
See Also
P6 Integration API Setup Tasks for On-Premises
Changing Database Configuration Settings for P6 Integration API
Enabling the Java Security Manager
Configuring Integration API Server Settings
Last Published Monday, July 14, 2025
