Configuring Summarizer in Services Settings
Primavera P6 Administrator Setup Tasks > About the Configurations Tab in the Primavera P6 Administrator > About the Primavera P6 Administrator Services Settings > Configuring Job Services in Services Settings
If you are running services and P6 on the same server, you should keep the defaults. If you have summarizing work that needs to be done immediately, you should set the Interval low (for example, 10s) and the Concurrent Threads high (for example, 20). Remember that if the server is actively doing summarizing work, all users will experience delays in the application.
To set your summarizer settings:
- Open the Primavera P6 Administrator.
- In the Configurations drop-down list, select your configuration.
- In the sidebar select Services/Job Services.
- Select Summarizer.
- In the Interval field, enter the amount of time the Summarizer will wait before summarizing the next available job.
The default value is 10s.
Enter a value between 1s and 24d20h31m23s647.
- In the Concurrent Threads field, enter the number of processes used for this service on this server. A value of 0 indicates that that this job will not run on this server.
The default value is 2.
Enter a value between 0 and 20.
- In the Active Mode field, select true if you want jobs processed continuously until all jobs finish. Select false if you want each job processed according to the Interval.
- In the Maximum Duration to Summarize field, enter the maximum activity duration that the summarizer will handle. Any projects that contain activities with durations longer than this setting will fail summarization and an error will be displayed for that project.
The default value is 100,000.
Related Topics
Configuring Scheduler in Services Settings
Configuring Leveler in Services Settings
Configuring Apply Actuals in Services Settings
Configuring Unifier in Services Settings
Configuring Overallocation Check in Services Settings
Configuring Global Replace Service in Services Settings
Configuring CopyProject in Services Settings
Configuring Baseline in Service Settings
Configuring GatewaySynchronization
Configuring Store Period Performance in Services Settings
Configuring Recalculate Assignment Cost in Services Settings
Configuring Rename Document Folder in Services Settings
Configuring CopyWBS in Services Settings
Configuring Export Excel in Services Settings
Configuring Import/Export Enterprise Data in Services Settings
Configuring Generate Reports in Services Settings
Configuring Checkin Enterprise Data in Services Settings
Configuring Checkout Enterprise Data in Services Settings
Configuring Preview Baseline in Services Settings
Last Published Monday, July 14, 2025
