Configuring Asynchronous Jobs in Services Settings
Primavera P6 Administrator Setup Tasks > About the Configurations Tab in the Primavera P6 Administrator > About the Primavera P6 Administrator Services Settings > Configuring Infrastructure Services in Services Settings
If you are running services and P6 on the same server, you should keep the defaults. If you want to apply the service immediately, you should set the Interval low. Remember that if the server is actively applying the service, all users will experience delays in the application.
To set your asynchronous jobs service settings:
- Open the Primavera P6 Administrator.
- In the Configurations drop-down list, select your configuration.
- In the sidebar select Services/Asynchronous Jobs.
- In the Purge Interval field, enter how often to remove long running job records from the database.
The default value is 1h.
Enter a value between 1m and 24d20h31m23s647.
- In the Grace Time field, enter the minimum age of long running job records removed during purge.
The default value is 1d.
Enter a value between 0 and 24d20h31m23s647.
Related Topics
Configuring Module Access Service in Services Settings
Configuring Timestamp Service in Services Settings
Configuring Mail Service in Services Settings
Configuring Registry Service in Services Settings
Configuring Next Key Service in Services Settings
Configuring Alert Notification Service in Services Settings
Configuring Collaboration Synchronization Service in Services Settings
Configuring Project Hierarchy Cache in Services Settings
Last Published Monday, July 14, 2025
