Configuring SAML Token Profile Settings for P6 EPPM Web Services
Primavera P6 Administrator Setup Tasks > About the Configurations Tab in the Primavera P6 Administrator > About Configuring P6 EPPM Web Services in the Primavera P6 Administrator
To set your SAML Token Profile settings:
- Open the Primavera P6 Administrator.
- In the Configurations drop-down list, select your configuration.
- In the sidebar select Web Services/Security/Authentication/SAML Token Profile.
- In the Require Signed SAML Token field, select true to require signed SAML tokens or false to require unsigned SAML tokens.
- In the SAML Version field, select one of the following:
- 1.1
- 2.0
- Both
- To configure SAML Tokens settings:
- Select Disable Timeout to use IssueInstant Timeout and AuthenticationInstant Timeout fields.
- In the Issuer field, enter the valid issuer for the SAML token. Use a space to separate multiple valid issuers. For example,
http://your.saml.issuer.com
- In the IssueInstant Timeout field, enter the value for the IssueInstant timeout. The value specified indicates the maximum time allowed between the time the token is issued and the time the token is received by the web service.
The default value is 5m.
Enter a value between 5m and 24d.
- In the AuthenticationInstant Timeout field, enter the value for the AuthenticationIssueInstant timeout. The value specified indicates the maximum time allowed between the time the token is issued, the time the user is authenticated, and the time the token is received by the web service.
- To configure Signed SAML Tokens settings:
- In the KeyStore Type list, select the KeyStore type.
The default value is JKS. JCEKS is also supported.
- In the File Location field, enter the absolute path to the keystore file. This file must exist on the local filesystem. For example,
c:\keystore\keystore.jks - In the KeyStore Password field, enter keystore password.
- In the Certificate Alias field, enter alias for the client certificate containing the public key.
The default value is alias.
- In the Private Key Alias field, enter the alias for the private key.
The default value is privatekeyalias.
- In the Private Key Password field, enter the password for the private key alias.
Related Topics
Configuring Authentication Mode for P6 EPPM Web Services
Configuring Username Token Profile Settings for P6 EPPM Web Services
Configuring Message Protection Settings for P6 EPPM Web Services
Last Published Monday, July 14, 2025
