Define maximum ID lengths (P6 Professional Only)
- Choose Admin, Admin Preferences.
- Click the ID Lengths tab, then specify the number of characters each code may have. Valid values are 1-40.
Note
- If you change the maximum number of characters in a code length, your change only applies when you add new codes or edit existing codes.
Last Published Wednesday, October 29, 2025
