Activity Code Definitions - Project dialog box
Use the Activity Code Definitions – Project dialog box to create, edit, and delete activity codes for the open project. You can use these codes to sort, filter, group, and report the open project's activity information.
Display Options bar: Click to search for a specific activity code.
Activity Code: Lists activity codes for the open project.
Activity Code Name: The name of the selected activity code. You can type a new name.
Max Length: The maximum number of characters the selected code's values can have. Type or click the arrows to select a new number.
Add: Adds an activity code.
Delete: Deletes the selected activity code.
Shift Up: Moves the selected code to a higher position in the display. This changes the order in which the codes display when you assign a code to an activity.
Note
- This button is available only with the manual display order. An outline symbol in the Code Value column label indicates a manual display order.
Shift Down: Moves the selected code to a lower position in the display. This changes the order in which the codes display when you assign a code to an activity.
Note
Make Global: Changes the selected project activity code and its values to a global activity code with global values.
Make EPS: Changes the selected project activity code and its values to an EPS-level activity code.
Last Published Tuesday, March 4, 2025
