Assign work products and documents to an activity from the Activities window
- Select the activity.
- Display Activity Details, then click the WPs & Docs tab.
To display the WPs & Docs tab, click the Layout Options bar and choose Bottom Layout Options. In the Available Tabs section, select WPs & Docs, click , then click OK. - Click Assign.
- Select the work product or document you want to assign, then click the Assign button. You can select only work products or documents that were created for the project to which the activity belongs.
- Click .
Tip
- To view work product and document details, such as author or description, or to open and view a work product or document, select it in the WPs & Docs tab and click Details.
Related Topics
Last Published Wednesday, April 10, 2024
