Create project-level activity codes
Structuring Projects > Defining Project, Resource, and Activity Codes > Activity Codes > Defining Project Activity Codes and Values and Values Colors
- Choose Enterprise, Activity Codes.
- Choose Project, then click Modify.
- Select the project to which you want to add the activity code and click Add.
- Type the name of the project activity code.
- In the Max Length field, specify the maximum number of characters for the activity code's values.
- Click Close.
Tip
- To change the order in which project activity codes are listed, select the activity code you want to move in the Activity Code Definitions dialog box, then click Shift Up or Shift Down.
Last Published Tuesday, March 4, 2025
