Create project codes
- Choose Enterprise, Project Codes.
- Click Modify.
- Click Add, then type the name of the project code.
- In the Max Length field, specify the maximum number of characters for the project code's values.
- Click Close.
Note
- If you intend to use reporting software, avoid using commas when creating data other than Project names. The way that data is passed to some reporting software can cause a comma to be interpreted as a delimiter between data items.
Tip
- To change the order in which project codes are listed, select the project code you want to move in the Project Code Definitions dialog box, then click Shift Up or Shift Down.
Last Published Tuesday, March 4, 2025
