Curtain Attachment dialog box
Use the Curtain Attachment dialog box to highlight a specific time period in a Gantt Chart. This dialog box contains the following elements:
Display curtain attachment: Mark or clear the checkbox to display or hide the curtain attachment.
Start Date: Click the Browse button to select a start date for the curtain display.
Finish Date: Click the Browse button to select a finish date for the curtain display.
Color: Click to select a color for the curtain.
Fill Pattern: The fill pattern of the selected curtain's start and finish dates.
OK: Click to accept changes.
Cancel: Click to close the dialog box without saving changes.
Delete: The delete button is available when you are using the dialog box to edit an existing curtain. Click to remove the curtain from the Gantt Chart.
Tip
Last Published Tuesday, March 4, 2025
