Customize a Resource Analysis layout
You can customize an existing Resource Analysis layout by specifying options that determine the data that are displayed and how they are displayed.
The Resource Explorer window displays to the left of the Bottom Layout window. You select resource elements in this window to control the data that you want to display in the resource profile or spreadsheet. You can filter, group, and sort the resource information in this window. You can also change the font, colors, and row height and specify which columns are included.
For the Gantt Chart and column data that display next to the chart in the Top Layout window, you can
When you display the profile or spreadsheet, you can configure the following options in the Top and Bottom Layout windows
When you display the stacked histogram for the profile, you can configure the following options in the Bottom Layout window
Note
Related Topics
Last Published Tuesday, March 4, 2025
