Customize activity column titles
  1. Choose View, Columns.
    You can also click the Layout Options bar and choose Columns.
  2. In the Available Columns or Selected Options section, select the column whose title you want to change.
  3. Click Edit Column.
  4. In the Edit Column dialog box, type a new title, then click OK.
    You can also specify a new width and alignment for the column.
  5. To update columns in the Activity Table, click OK, or to view your changes without closing the Columns dialog box, click Apply.
Notes
Last Published Tuesday, March 4, 2025
