Cut, copy, or paste a statement
  1. Choose Tools, Global Change.
  2. Select the global change specification you want to edit, then click Modify.
  3. Select the statement you want to cut or copy, then click either Cut or Copy.
  4. Click the section into which you want to paste the statement.
  5. Click Paste.
    The new statement is placed at the bottom of the list of statements.
Note
Last Published Tuesday, March 4, 2025
