Delete a work breakdown structure element
  1. Choose Project, WBS.
  2. Select the WBS element you want to delete, then choose Edit, Delete.
    If the WBS element you want to delete is assigned to activities, you are prompted to delete the WBS element and all activities assigned to it or reassign all of its activity assignments to the element's parent WBS element.
  3. Click OK, then click Yes.
Note
Related Topics
Edit a work breakdown structure element
Parent Element
Last Published Tuesday, March 4, 2025
