Delete work product or document records
- Choose Project, Work Products and Documents, then select one or more work product or document records.
- Choose Edit, Delete, then click Yes.
Note
- Deleting a work product or document record deletes the work product or document record in the project. It does not delete the actual document file.
Last Published Friday, October 4, 2024
