Display work product and document details in the Work Breakdown Structure window
- Choose Project, WBS.
- Select a WBS element associated with the work product or document.
- Display WBS Details, then click the WPs & Docs tab.
To display the WPs & Docs tab, right-click in the Details area and choose Customize WBS Details. In the Available Tabs section, select WPs & Docs, click , then click OK. - Select the work product or document, then click Details.
To view the work product or document, click Launch next to the appropriate Location field.
Note
- Only P6 Professional users can open private location documents. Public location documents can be viewed by all project participants.
Related Topics
Display work breakdown structure details
Last Published Friday, October 4, 2024
