Edit Column dialog box
Use the Edit Column dialog box to customize column titles. You can also set the column width and the alignment (left, centered, or right) of each column's title and contents. The changes you specify apply to the current layout or dialog box only.
Default Title: The original title for the column.
New Title: The current title for the selected column. You can type a new title.
Width: The column's width in pixels. Change the width by choosing a number from 10 to 1000.
Alignment: Choose the alignment for the column title and the contents of the column. Choose Left, Center, or Right.
Default: Applies the default column title to the currently selected column.
Last Published Tuesday, March 4, 2025
