Exporting and Importing Layouts
Exporting a layout
  1. In the Project menu, choose Activities, or Resource Assignments, or WBS to open the respective layout. Or, choose Enterprise, Projects to open a project layout.
  2. Choose View, Layout, Open.
    You can also click the Layout Options bar and choose Layout, Open.
    You are prompted you to save the current layout.
  3. Highlight the layout you would like to export.
  4. Click Export. Browse to the location where to save the . plf file.
  5. Click Save.
Importing a layout
  3. Click Import.  The application responds by prompting you to choose a . plf file.
  4. In the Import Layout As dialog box, type an appropriate name for the layout.
  5. In the Available To field, select a user category.  Depending on your privileges, you will be able to choose All Users, Another User, Current User, or Project.
    • If you  selected Another User, in the User field, click to specify a user.  The Select User dialog box displays.
    • If you selected Project, in the Project field, click to specify a project. The Select Project dialog box displays.
    Note: Only currently opened projects will appear in the Select Project dialog box.
  6. Click Save.
Last Published Tuesday, March 4, 2025
