General tab - Project Details
Use this tab to view or modify general information for the selected project or node.
EPS ID/Project ID: The node/project identifier. You can type a new unique ID in this field or directly in the ID cell within the hierarchy display.
EPS Name/Project Name: The node/project name. You can type a new name in this field or directly in the name cell within the hierarchy display.
Status: The status of the selected project (not applicable for EPS nodes). Use status to identify active or inactive projects. You can also select What If status for analysis before establishing a more permanent project schedule, or Planned status for use during the project planning phase.
Responsible Manager: The node's/project's assigned organizational breakdown structure (OBS) element. A responsible manager is required for each level of the EPS. You can edit this name or click to select a different OBS element.
Note
- To change the responsible manager for a project, a user must have Project Superuser access rights.
Project Leveling Priority: A user-defined rank of the project among other projects used during leveling. P6 Professional uses this number to determine which assignments from other projects to consider within the leveling run. For example, if you specify 5 in the Consider Assignments in Other Projects With Priority Equal/Higher Than field of the Level Resources dialog box, P6 Professional considers all projects with a project leveling priority of 1, 2, 3, 4, and 5.
Enter a value from 1 (highest priority) to 100 (lowest priority).
Check Out Status: Indicates whether a project is being used remotely. This feature enables version-control of projects. You can also change the status of the project to "checked in" or "checked out". For example, if a project was checked out, no changes were made, and you would like to work with the project from the live database without having to import the project, change the status to "checked in."
Checked Out By: The name of the user that checked out the project. This field is blank when the Check Out Status is Checked In.
Date Checked Out: The date and time the user checked out the project. This field is blank when the Check Out Status is Checked In.
Project Web Site URL: The project's Web site address, if applicable.
Launch: Launches the Web site specified in the Project Web Site URL field.
Last Published Tuesday, March 4, 2025
