General tab - Users dialog box (P6 Professional Only)
Login Name: The selected user's login name. You can type a new login name, between 1 and 255 characters.
If P6 Professional is running in LDAP authentication mode, the login name you enter is checked against the LDAP store. If the user is not found, a message displays to notify you that the user cannot be added.
Personal Name: The selected user's name. You can type a new name.
Password: Click to change the selected user's password. To change your own password, select your user name, then click this button. A password must be between 1 and 20 characters.
Resource ID / Resource Name for Personal Calendar: The selected user's resource name. Click to select a resource.
Related Topics
Admin Preferences dialog box (P6 Professional Only)
Last Published Tuesday, March 4, 2025
