Identify a document as a work product
You can identify a document as a work product if it is assigned to a WBS element or activity.
- Choose Project, Work Products & Documents, then select the document.
- Display WP & Doc Details, then click the Assignments tab.
- If the document is already assigned to the WBS or activity for which it is a work product, mark the corresponding Work Product checkbox.
If the document is not yet assigned to a WBS element or activity, click Assign, then select the WBS element or activity to which you want to assign the document. Click the Assign button and the Close button, then mark the Work Product checkbox.
Related Topics
Display work product and document details in the WPs and Docs window
Last Published Wednesday, April 10, 2024
