Issue Navigator dialog box
Use the Issue Navigator dialog box to track the open project's issues. This includes associated activities, resources, and work breakdown structure (WBS) elements. The Issue Navigator dialog box is displayed when you click Issue Navigator on the Tools menu.
Display Options bar: Lists options for changing the issues display.
Issue Navigator table: Lists open issues (and associated details) including project issues, if any.
Tracking: Click to display the selected issue's details with its assigned tracking layout.
Note
- The Tracking button is only available if the selected issue has an assigned tracking layout.
Activities: Click to display the selected issue's Activity Details in the Activities window.
Note
- The Activities button is only available if the selected issue is associated with an activity.
WBS: Click to display the selected issue's work breakdown structure (WBS) details in the Work Breakdown Structure window.
Note
- The WBS button is only available if the selected issue is associated with a WBS element.
Resources: Click to display the selected issue's resource details in the Resources window.
Note
- The Resource button is only available if the selected issue is associated with a resource.
Issue Details: Click to display the selected issue's details in the Project Issues window.
Notify: Sends email about the selected issue.
Tip
- You can automatically display the Issue Navigator at startup. Choose Edit, User Preferences, and then click the Application tab.
Last Published Tuesday, March 4, 2025
