Open Project dialog box
Use the Open Project dialog box to open an existing project. You can select a portfolio to limit the amount of project data you open.
Select Project Portfolio: The currently selected portfolio. Only projects in the selected portfolio are available in the Open Project table. Click
to select a different portfolio. The project data loads into memory as soon as the portfolio is selected.
Display Options bar: Lists options for finding a specific project, print a list of projects, and customize the project display. You can also change columns, filter, font, and colors.
Open Project table: Lists all EPS nodes and the projects in the currently selected portfolio. Project Status lists the state of the project: planned, active, inactive, or what-if. Note that a padlock icon
on top of a folder icon indicates a user has the associated project opened in Exclusive access mode.
Tips
- To sort the display, click any column label.
- To hide EPS nodes that do not contain any projects for the currently selected portfolio, click the Display Options bar, then select Group and Sort by, Customize. Mark the Hide if Empty checkbox.
Open: Click to open the selected EPS node or projects.
Cancel: Closes this dialog box without opening any EPS nodes or projects.
Note
- If you select a new project portfolio, the data is loaded into memory immediately. Cancel will not undo this change.
Users: For each project or EPS node you select, click to view a list of all users who have the selected project(s) open. When you select an EPS node, the list displays users who have any project within the EPS node open.
Access Mode
Exclusive: Choose to open and edit the selected project, and you alone can edit the open project. When you open a project in Exclusive mode, other users can open it only in Read-Only mode.
Shared: Choose to open and edit the selected project at the same time that other users can open and edit the project in Shared mode. However, if another user has the project open in Exclusive mode, then you can open it only in Read-Only mode.
Read Only: Choose to open a selected project for viewing only.
Last Published Tuesday, March 4, 2025
