Preview Changes to Project dialog box
Use the Preview Changes to Project dialog box to choose which changes made to a reflection should be merged into the source project.
Group Changes by:
Subject Area: Shows all changes made to the project by table (activity, codes, documents, issues, etc).  Activity IDs will appear several times under the appropriate subject area band.
Activity: Shows all changes made to an activity under an activity band.  The Activity ID appears as a band.  Any changed areas for that activity appear in the corresponding band.  If any changes have been made to a project or WBS, these will also be displayed in their respective banding.
Select All: Marks all check boxes.  Note that changes are not actually merged until you press the Merge Changes button.
Clear All: Clears all check boxes.  Since all check boxes are selected by default, this option may be used to quickly mark a few check boxes by clearing all check boxes first.
Display: Reflection Differences: Displays a menu that permits you to perform the following operations: copy, select all, find, find next, print preview. expand all, and collapse all.
Status: Identifies the status of the field and includes the following values:
Field: Identifies the fields that have changed in the reflection.
Value before merging: Identifies data that populates this field in the source project.
Value after merging: Identifies data that populates this field in the reflection.
Prior to merging:
Create a copy of source project (x) as a baseline: Mark this check box to create a baseline to the source project which you can use to rollback the changes you made with this dialog box.
Create a backup file (.xer) of source project (x): Mark this check box to create a XER file which you can use to rollback the changes you made with this dialog box via an XER import.
 : Click to choose a location to save the XER file to.
After merging:
Keep reflection (x): Mark this radio button to keep the reflection in the database after merging it with the source project.
Delete reflection (x): Mark this radio button to clean up the database by deleting the reflection after merging it with the source project.
Replace reflection (x): Mark this radio button to replace the reflection with an updated reflection based on the current data in the source project after the merge.
Last Published Tuesday, March 4, 2025
