Print Toolbar
Use the Print toolbar to print the contents of the open window, preview print output, and define page and print settings. This toolbar is displayed by default.
The following table provides information about each available icon on the toolbar.
Icon
Function
Displays by default?
Shortcut keys
Corresponding menu command
Enables you to print the currently selected window, select a printer, and set printer options.
Yes
Ctrl+P
File > Print
Opens the Print Preview window. In the Print Preview window, you can define page and print settings, publish the contents of the selected window to an HTML file, and print the contents of the selected window.
Yes
None
File > Print Preview
Opens the Page Setup dialog box. In the Page Setup dialog box, you can define page size and orientation, set scaling options, change the size of margins, and define a header and footer.
No
None
File > Page Setup
Opens the Print Setup dialog box. In the Print Setup dialog box, you can select a printer and define printer properties.
No
None
File > Print Setup
Tip
Related Topics
Customizing toolbars
Last Published Tuesday, March 4, 2025
