Project Explorer window
The Project Explorer window, which lists the EPS structure, displays in the upper left pane of the Tracking window. A + sign before an item indicates it contains additional levels of detail. Click the + sign to open additional levels; when all levels for an item are open, the + changes to a minus sign. Click the – sign next to an item to close the detail levels below it.
Tips
Last Published Tuesday, March 4, 2025
