Project Portfolios dialog box
Use the Project Portfolios dialog box to view and change general information about the selected portfolio. You can also add and delete portfolios. The top portion of the Project Portfolios dialog box contains information about all available portfolios and lists the following kinds of portfolios:
Portfolios can be:
The lower portion is divided into tabs that display specific information about a selected portfolio. Select each tab name below to read about its features.
In addition, the following fields and buttons are available in the Project Portfolios dialog box.
Display Options bar: Click to display portfolio details; find a specific portfolio; and change the font, colors, and row height of items in the Project Portfolios dialog box.
Portfolio Name: The name of each available portfolio.
Note: Only the portfolio owner can change the name of a multiple user portfolio.
Add: Click to add a new portfolio.
Delete: Click to delete the selected portfolio.
Cut: Click to cut the selected portfolio so you can move it to another location.
Copy: Click to copy the selected portfolio so you can add it to an additional location.
Paste: Click to paste a portfolio that you have either copied or cut.
Related Topics
Projects tab - Project Portfolios dialog box
General tab - Project Portfolios dialog box
User Access tab - Project Portfolios dialog box
Last Published Tuesday, March 4, 2025
