Search only in titles Remove work product and document assignments from the WPs and Docs window Managing Projects > Adding and Assigning Work Products and Documents Select the work product or document. Display WP & Doc Details, then click the Assignments tab. Select one or more activity or WBS element assignments. Click Remove, then click Yes. Related TopicsDisplay work product and document details in the WPs and Docs window Last Published Wednesday, April 10, 2024
