Role in Use dialog box
Use the Role in Use dialog box to specify how you want to delete a role that is assigned to resources and/or activities.
Select Replacement Role: Choose to delete the selected role and reassign its resource and activity assignments to a replacement role you specify.
Delete Role(s): Choose to delete the selected role without reassigning its resource or activity assignments.
Last Published Tuesday, March 4, 2025
