Roles dialog box
Use the Roles dialog box to add, edit, and delete roles. You can also use the Roles dialog box to assign roles to resources, define up to five price/unit rates for each role, and specify role availability over time.
The Roles dialog box contains the following tabs:
In addition, the following fields and buttons are available in the Roles dialog box:
Display Options bar: Click to search for a specific role or change your roles display.
Role ID: Lists role IDs. To sort the display, click the Role ID column label.
Role Name: Lists each role's name. To sort the display, click the Role Name column label.
Add: Adds a role.
Del./Merge: Deletes the selected role.
Cut: Cuts the selected role so you can delete it or move it to another position in the list. Select a new position, and click Paste.
Copy: Copies the selected role so you can quickly create a similar role in another position in the list. Select an additional position, and click Paste.
Paste: Pastes the role you copied or cut.
Arrows: Moves the selected role to a different position in the display.
Related Topics
Units and Prices tab - Roles dialog box
Assign Resources dialog box
General tab - Roles dialog box
Codes tab - Roles dialog box
Last Published Tuesday, March 4, 2025
