Select a baseline for summarization
  1. Choose Project, Assign Baselines.
  2. In the Project field, select the project to which you want to assign a project baseline.
  3. In the Project Baseline field, select the baseline you want to use to summarize baseline project data.
    If you want to use the current project to summarize baseline project data, select the current project.
Last Published Tuesday, March 4, 2025
