Select Activities by Attribute dialog box (P6 Professional Only)
Use the Select Activities by Attribute dialog box to specify which of the activities for a selected attribute you want to include in your project plan.
Display Options bar: Click to change the activities display.
Activity table: Lists activities in the selected attribute. A checkmark indicates that the activity is selected.
Tip
Last Published Tuesday, March 4, 2025
