Select Currency dialog box
Use the Select Currency dialog box to select the currency in which you want to view all cost values.
Display Options bar: Click to change the currency display.
Search: Type a currency ID or currency name to display a filtered list of currencies whose ID or name begins with this value.
Currency ID: The ID for each available currency type.
Currency Name: The name of each available currency type.
Notes
- Only a user with Admin Superuser privileges can define the available view currency types.
- When you enter values in cost fields, they are always displayed in the view currency.
Last Published Tuesday, March 4, 2025
