Select EPS to add into dialog box
Use the Select EPS to add into dialog box to select the EPS node to which you want to add the new project.
Display Options bar: Click to change the EPS/project table display.
EPS/Project table: Lists the ID, name, and additional information about existing EPS elements. To sort the display, click a column label.
Select: Adds the new project to the selected EPS element.
Last Published Tuesday, March 4, 2025
