Select Project Code dialog box
Use the Select Project Code dialog box to select the project code to filter by in the Project Codes dialog box.
Display Options bar: Click to change the display.
Project Code: Lists the available project codes.
Select: Assigns the selected code to the filter.
Last Published Tuesday, March 4, 2025
