Select Resource dialog box
When P6 Professional is connected to a P6 EPPM database, use the Select Resource dialog box to assign a resource to an issue, to a user, or to a personal resource calendar. When P6 Professional is connected to a P6 Professional database, use the Select Resource dialog box to assign a resource to an issue, to a user, or to a personal resource calendar. Also use this dialog box to select the resource under which to place all resources from a Microsoft Project file during import.
If resource security is enabled, you can select resources only from under your resource root node or from current project resources.
Display Options bar: Lists options for changing resource columns, filters, grouping and sorting, font, and colors.
Note: When the Filter By, All Resources option is used, all resources display, even those assigned a personal resource calendar.
Select Resource table: Lists your organization's resource hierarchy. To sort the display, click a column label.
Select: Applies your selection and closes this dialog box.
Close:
When connected to a P6 EPPM database: Removes the selected resource from the current activity, issue, or user.
When connected to a P6 Professional database: Removes the selected resource from the current activity, issue, or user.
(This option does not display during the Microsoft Project import.)
Related Topics
Last Published Tuesday, March 4, 2025
