Select Resources dialog box
Use the Select Resources dialog box to select specific resources for a leveling run.
Display Options bar: Click to change fonts and colors in this dialog box.
Level: Mark the checkbox beside each resource that you want to include in the leveling run. Clear the checkbox beside a resource if you do not want to include it in the leveling run.
Resource Code: Displays the resource name.
Max Units/Time: Shows the number of units the resource is available during each workperiod.
Select All: Click to select all resources in the list for the leveling run.
Clear All: Click to clear all of the checkboxes in the Level column.
Last Published Tuesday, March 4, 2025
