Assign Role dialog box
Use the Assign Role dialog box to assign a role to the selected resource or activity.
Display Options bar: Click to change the roles display.
Search: Type a role ID or name to display a filtered list of roles whose ID or name begins with this value.
Role ID: Lists role IDs. To sort the display, click the Role ID column label.
Role Name: Lists each role's name. To sort the display, click the Role Name column label.
Assign: Assigns the selected role.
Remove: Removes the selected role assignment.
Last Published Tuesday, March 4, 2025
