Specify a format for dates
  1. Choose Edit, User Preferences.
  2. Click the Dates tab.
  3. In the Date Format section, select the order in which you want all dates to appear.
  4. In the Time section, specify how or whether you want to display time.
  5. In the Options section, select the date formatting options you want to apply.
Last Published Tuesday, March 4, 2025
